Cool @sat 61.5 problem
Username: Mike_s73
Westland, Mi
i have one dish 500 pointed to 110 and 119 and second dish 18 inch pointed to 61.5. with my dish receiver my signal is great and they working fine for many years with SW-64.
i bought cool @sat 5000. I hookup my cool@sat 5000 through the diseqc switch i can pick signal for the 110 and 119. i get green for both sat. and open channles. but don't get siganal for 61.5. i try to scan it many differenent ways but i can't get the siganl(one at a time with sw21 and sw 64 etc.). do i have wrong LNBf at 61.5 or it is something else. because with dish receiver i have very strong signal near 125%. Please help me on this.
Username: Dellworkshop
Post Number: 9
61.5 dosent give a green signal, but you need to go to the motorized setting and it picks up from transponder 5 and upward...1 thorugh 4 dosent have any signals...i am not good at this, but hope it helps,...
Username: Mike_s73
Westland, Mi
Thank steve
I got mine working, exactly the same transponder 5 has to selected in mannual mode then go in auto scan and select the dish and scan. i use the SW21 switch which works fine.
