New member Username: Rick_rossPost Number: 1 Registered: May-06 | I have 2 4 ohm dvc subs and need to hook them up at 1 ohm to a amp that is 1100 rms x 1. Right now i have them each hooked up to seperate amps bridged on them for 500 rms at 4 ohms. would i take them out of the box and change the way they are wired or keep them like that. Also both subs have seperate speaker wire so if the amp is 1100 x 1 do you put both + from the subs into the 1 + on the amp and both - from the subs into the 1 - on the amp? |
Silver Member Username: Alias747MN Post Number: 925 Registered: Apr-05 | So you are saying that you have each sub hooked up to a 2 channel amp brigded @ 4-ohms? Sorry but there is no way to hook up a DVC 4-ohm sub for 4 ohms, it's not possible. As for hooking up the 2 subs together to make a 1 ohm load on the mono amp, that is possible. Just do a parrallel/parallel hook up and yeild a final 1 ohm load. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 619 Registered: Dec-05 | www.the12volt.com hit the link woofer wiring so you can figure it out jeje |
Gold Member Username: TjmutlowPost Number: 2111 Registered: Sep-05 | Isaac, you can hook 2 dual 4 to a 4ohm bridged, |
Silver Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 800 Registered: Aug-05 | i think he says how to hook up 2 dual 4ohm subs to make 1 ohm.....http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2...or if u have two outputs (like my Mb quart Raa-1000) u can just wire each sub up for 2 ohms....and run into each output... but just twist the wire together...an put it into the amp... everyday im hustlin chevy ridin high some might understand y i wrote that...lol |
Silver Member Username: James_gTN Post Number: 489 Registered: Jul-05 | Ty, He's using two amps right now. Only way he could have it at 4 ohms is if he's using two 4-channel amps bridged, which would be a little weird. |
