Last check
Username: Splmonster
Post Number: 109
well i have everything ordered so i cant really go back but just wanted to make sure everything would wire up ok and nothing would like blow up or anything, here it is
pioneer 680mp
kicker kx600.1
15" ascenadant audio arsenal
Username: Goatin
Ohio U.S.A
Post Number: 1081
If your Arsenal is 2 ohm then yes.
Post Number: 110
somebody in the HU sections said something about giving my HU 2 ohms will fry it or something... thats main reason i wanted to know
Username: Goatin
Ohio U.S.A
Post Number: 1083
No offense but what you just said made no sense to me.
They might have been talking about connecting too many speakers directly off your HU.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2168
if you put a 2 ohm load on your HU's internal amp you will fry it.
also, that KX600.1 puts out its max power rating at 1 ohm. the AA Arsenal is a dual 4 ohm sub, so it can only be wired at 2 or 8 ohms. not going to be a good match.
