i made the middle part a little long, but it would go just left of the port and that thing in the middle would be a little shorter... would i add the port cf to the total cf of the box or is the port sometehing on its own?
ok, so im thinkin tunin it to 31Hz. and havin 1.2 cf for the sub before displacement... does that sound good? my JL 10w6v2's is going in the boxes, i'll make 2
Longer the box, straighter the port the better. You can bend ports but the fact is when doing so you create turbulance which can waste energy/sound output. Also remember, more you subject the sound to material by winding it around more saturated the walls will get causing an even further loss, mening the MDF will absorb some of the sound... Polo.
