New member Username: Freezeman_7Post Number: 1 Registered: May-06 | Im purchasing 2 12' Re SX subs and was looking at a fusion Jonah Lomu#11 FJL-1611D http://fusioncaraudio.com/products.php?category_id=20 and i was wondering if that would be enough power to the 2 subs... they are rms'd at 1000 a peice... and i have a regular 12.6 volt car battery with the stock alternator.. just tell me if ill need more power.. or if that is plenty.. thanks |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 2953 Registered: Sep-04 | your definetly going to need a 250a alt. |
New member Username: Freezeman_7Post Number: 3 Registered: May-06 | ok... do u think that amp has enough power to get a good sound?? |
Bronze Member Username: Livin_loudNy Post Number: 91 Registered: Jan-06 | Well I can't see the specs of the amp. But if its putting out from a minimum of 1200rms to a max of 2200rms you'll be good. |
New member Username: Freezeman_7Post Number: 4 Registered: May-06 | i think this link might work http://fusioncaraudio.com/products.php?action=view&product_id=99 and i think the rms bridged is 1350 not for sure though... all i know is its a mono amp... thats all i can see.. their site is messed up |
New member Username: Freezeman_7Post Number: 5 Registered: May-06 | BUMP^^^ |
