Rovin, wut are your type r's tuned 2???
Username: Thomas_g
NM
Post Number: 498
Rovin, wut are your type r's tuned 2??? PVC port?
Username: Young_james
Post Number: 1493
I think his is 35-36, somewhere around there. Correct me if I'm wrong Rovin.
I have a type R tuned to 38 and it get's thumpin pretty good :-)
Username: Rovin
Trinidad & T...
Post Number: 7865
James ur not really wrong cause i have experimented with tuning my Rs @ freqs from 31-36hz & i change it kinda often
well i have 2 sets of 3" pvc ported boxes from previous subs so im reusing those
1 set is 1.65cut
2nd set is 1.88cuft
if u want SQ then 31hz is sweeeet & very accurate but u lose SPL
36 is loud but SQ will drop
my fav combo so far with a nice balance of SQ/SPL is 1.65cuft 33hz - of course my ride is a hatchback so it will song differently in different cars ...
https://www.ecoustics.com/electronics/forum/car-audio/189456.html
Username: Thomas_g
NM
Post Number: 531
Tight. So which tuning do you like better? For you?
Username: Thomas_g
NM
Post Number: 532
33hz tight.
Post Number: 1494
my is 38 and I DEFF loose SQ. Not very musical but nice for those low notes
Username: Rovin
Trinidad & T...
Post Number: 7876
u see thats what i like about pipe port - u ca neasily change it out anytime u want & the box takes up less space/weight than slot ported ......
Username: Thomas_g
NM
Post Number: 535
I liked it too but my prob was that id alwayz get port noise.
Username: Rovin
Trinidad & T...
Post Number: 7878
strange how ppl always say they get pipe port noise but honestly i never got any from mine cause i sand paper the edges smooth on my ports & its sounds good .......
