2 kicker s15l7 with the kx 2500.1
Username: Kkali
Los Angeles, California Usa
will this be a good spl setup? and anybody with this same set up what are u hitting db wise
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2110
yes. don't know how maby dB's. that'll depend on the box and car they are going in.
Stockbridge, GA USA
Post Number: 2111
many, not maby, lol
Username: Andysd03
Post Number: 93
kicker2500.1 is 2 ohm stable arnt those subs dual 4's? and 2 would make it 1ohm anyone know if kicker amp can handle 1 ohm?prob not.
Username: Livin_loud
Ny
Post Number: 83
The KX1200.1 can run 1 ohm, but no the KX2500.1 can't... kinda weird why they did that. And yeah, you would need 2 ohm model subs (which I actually have) to run off that amp at 2 ohms. A ported box giving each sub at least 4 cubes or both at least 5 will probably be hitting 145+ dB, but as said above it depends on the vehicle and box placement.
Username: Kkali
Los Angeles, California United States
alright what amp would be best to power these
Ny
Post Number: 116
I think it would be easier for you to get different subs that can run off that. It's a great amp...
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1052
i hit 149.6 with the same setup. sount like crap though
Username: Kkali
i might just end up getting 2 13w7s with 2 jl 1000/1 amps better idea u think?
Username: Kkali
i know that jl is a sq subwoofer but would the two 13w7s hit hard?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1055
get two 15" eclipse ti's. they will be louder than the l7's (should be) and sound much much better
