5x7 and 5.25 speakers, need help!!! thanks
Username: Ishkabobble55
Erie, Pennsylvania
Post Number: 281
i have a 1994 ford f250 and im trying to find some speakers 2-5x7"s and 2- 5.25"s, any suggestions would be great. price range is about $150-$200 just looking to upgrade the stock speakers to some better sounding ones. i do not want to amp them. full range or components, both will work. thanks
Username: Alteraudiousa
Concord
Post Number: 804
you will need coax's. its 5x7 all the way around so you'll need adapters to fit a 5.25. If you go store brands I would say the Kenwoods would fit your budget best if its 200$ for both fronts and rears, the MTX's fit the budget too. If you go 5.25 they're others out there. May look into CDT.
Erie, Pennsylvania
Post Number: 283
i wasnt sure what the front sizes were, but if they are 5x7's that would be fine. i dont really care for your mentioned brands though, ive heard them both. maybe CDT i'll have to check them out. any other brands
