Bronze Member Username: AnacardDimond Bar, CA United States Post Number: 23 Registered: Jul-05 | can it be done? or would i need a bigger alt ? they are going in the back seat of my cadillac ext. |
Silver Member Username: PanochaPost Number: 132 Registered: Jun-05 | lol youre gonna need a new alt alright. |
Bronze Member Username: AnacardDimond Bar, CA United States Post Number: 25 Registered: Jul-05 | i am just hopeing it will hang i have a bunch of other stuff i need in there. |
Silver Member Username: Matt12490Benicia, California USA Post Number: 854 Registered: May-05 | 600 amp alt?? or do you mean dual 300 amp alts? i cant find info on that amp i think you might have a typo there. either way if its 4000 watts rms then you will be fine |
Bronze Member Username: AnacardDimond Bar, CA United States Post Number: 26 Registered: Jul-05 | sorry about that Zapco c2k4kw...thats the one....well i dont know about it ...there are a cuple of others i could roll with.. |
Gold Member Username: CarguyPost Number: 5550 Registered: Nov-04 | Are you sure you can fit 2 RE 18" MT in your car? First off, what will be the tuned port frequency? For my 15" MT, it needed at least 5 cu ft of volume. 18" will require probably 6 or more. That is a huge volume to give in a car. You will probably need a van for them. |
Silver Member Username: Killerzracing71Fredericksburg, Virginia United states Post Number: 751 Registered: Aug-05 | "cadillac ext" u dont think he can fit in the back of the bed....12 cuft...or less...taking up the whole thing |
Gold Member Username: B101Queen City, NC USA Post Number: 2811 Registered: Sep-05 | nice setup too me... just use 3/4 the bed as the box, facing into the cabin, port it inside the cab.. slap the 4kw on them, its a WRAP like rentals after that.. i think people are making their own alternators now.. lol NO such thing as a 600a.... FYI the largest alternator built is like a 350a, and Ohio Gen charges out the butt for that.. so do a dual 300a setup! not like u can do a Steve Meades setup in the EXT.. MEADE his self.. he said he was VERY proud of this install... dual 300a alternators 4 MT 18s 2 4KW Zapcos lol, thats enough, let me know if yall want more... ohh almost forgot he WON>> |
Silver Member Username: Sw9152Michigan Post Number: 696 Registered: Feb-06 | meade is my idol.... |
Silver Member Username: Livin_loudNy Post Number: 112 Registered: Jan-06 | That's Chicken's (Chicken?) Escalade off RoE. F*cking thing is insane... I don't know how that truck holds together... And can somebody please tell my why he as an alligator on his ceiling? haha http://realmofexcursion.com/videos/Various/meade02.wmv |
Gold Member Username: B101Queen City, NC USA Post Number: 2819 Registered: Sep-05 | Meade did the install for Chicken... I forgot what it meters, its loud as sh!t..... |
Gold Member Username: B101Queen City, NC USA Post Number: 2821 Registered: Sep-05 | it has gator hangin from roof, and gator leather interior... |
Silver Member Username: ShmanGrandville, Michigan United States Post Number: 236 Registered: Mar-06 | steve meade is way too dominant, everything he touches turns to pure gold....lol |
