Help wiring CVRS!!!!!
Username: Stnorris
Post Number: 46
MY subs are both dual 2 ohm, and my amp is 2 ohm stable. I want to know if this will work for my subs???
http://www.freewebs.com/lifelessinabox/index.htm
i want to wire the subs to themselves inside the box, then go to the terminals...then wire the subs together (with pos and pos and neg and neg)on the outside of the box.
The diagram is similar to this one:
OPTION 2!
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2
Will my drawn diagram work???
Username: Stnorris
Post Number: 48
ANYONE THERE???????!???
Username: Stnorris
Post Number: 49
HELP ME please
Username: Rideredder
Cornell, IL USA
Post Number: 350
This is the diagram that I used to hook two DVC 4Ohm subs to 4Ohms, so it should work for you too.
Username: Tjmutlow
Post Number: 2059
it should work fine, it would create a 4ohm load per side in box, then a 2ohm at the amp....
