12' Resonant Engineering SX Subs
Username: Freezeman_7
Im purchasing 2 12' Re SX subs and was looking at a fusion Jonah Lomu#11 FJL-1611D http://fusioncaraudio.com/products.php?category_id=20 and i was wondering if that would be enough power to the 2 subs... they are rms'd at 1000 a peice... and i have a regular 12.6 volt car battery with the stock alternator.. just tell me if ill need more power.. or if that is plenty.. thanks
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2953
your definetly going to need a 250a alt.
ok... do u think that amp has enough power to get a good sound??
Username: Livin_loud
Ny
Post Number: 91
Well I can't see the specs of the amp. But if its putting out from a minimum of 1200rms to a max of 2200rms you'll be good.
i think this link might work http://fusioncaraudio.com/products.php?action=view&product_id=99 and i think the rms bridged is 1350 not for sure though... all i know is its a mono amp... thats all i can see.. their site is messed up
BUMP^^^
