New member Username: Eagle99Post Number: 1 Registered: May-06 | I have a cooltec 4000pro. I input the new keys for N2. but it did not work. any helps will be appreciated! |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 66 Registered: May-06 | Maybe do you need scan all satellite or delete all channels and scan again. |
New member Username: Eagle99Post Number: 2 Registered: May-06 | Hi Eva Diaz I had tried re-scan but no luck.what I inputed was: Nagravision 2 Ident: 0101 00 AE F1 0F 87 F9 58 E1 55 00 3A E4 8B AE ED DB BB DF 01 C5 6C 66 89 3A 32 D0 C9 01 24 2B F0 4F 03 68 06 92 Then I re-scaned it. any wrong ? Thanks, |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 69 Registered: May-06 | Delete all channels and scan again. |
New member Username: Eagle99Post Number: 3 Registered: May-06 | I just tried to delete all channels and scan again but nothing changed, still Scramble channels. thanks, |
Silver Member Username: The_wank_artistPost Number: 138 Registered: Feb-06 | Try an Autoscan. |
New member Username: Eagle99Post Number: 4 Registered: May-06 | yes, I did autoscan. do I need to change something in Nagravision 1 area? Thanks, |
Silver Member Username: The_wank_artistPost Number: 140 Registered: Feb-06 | Not if your looking for DN channels. Those are in Nag2. Are we missing something??? |
New member Username: Eagle99Post Number: 5 Registered: May-06 | is this correct? Thanks, |
New member Username: Eagle99Post Number: 6 Registered: May-06 | This is the Nagravision 1 screen. I did not change any of them. |
Silver Member Username: The_wank_artistPost Number: 144 Registered: Feb-06 | That looks correct. |
New member Username: Eagle99Post Number: 7 Registered: May-06 | any suggestions? Thanks, |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 75 Registered: May-06 | Is very strange if you do not see any channels. Maybe you box is lock in any place, if you have auto roll try disable. Check if you can scan transport too. Lucky |
New member Username: Eagle99Post Number: 8 Registered: May-06 | all those channels are scramble and the signal quality is very good. I do not have auto roll. and could you please tell me how to scan tansport? Thanks |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 78 Registered: May-06 | http://best-dish.com/cooltec.html |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 79 Registered: May-06 | If you still have issues you must do a factory reset and rescan your channels in. Do you need copy and paste this address remove *** |
New member Username: Eagle99Post Number: 9 Registered: May-06 | thanks a lot, I'll try |
New member Username: Eagle99Post Number: 10 Registered: May-06 | is the cooltec same with c00lsat? Thanks |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 80 Registered: May-06 | Maybe do you need a patch for you cooltec read in this site. Here is the patch for new Cooltec receivers AND loader. No More malicious Cool*sat bomb to worry about. remove *** |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 81 Registered: May-06 | Cooltec i mean is the clon of cool**sat. |
Bronze Member Username: Eagle99Post Number: 11 Registered: May-06 | Thank you so much, Eva |
Bronze Member Username: EvadelparaisoPuerto Rico Post Number: 82 Registered: May-06 | I was glad to help you. |
Gold Member Username: LklivesPost Number: 2428 Registered: Jan-06 | its lines 10-11-20-21 for nagra2...same as coo*lsat! |
Bronze Member Username: Eagle99Post Number: 12 Registered: May-06 | I tried to use lines 10-11-20-21 but no luck |
Bronze Member Username: Eagle99Post Number: 13 Registered: May-06 | Hi everyone, I tried to load the new patch to my cooltec 4000pro with 9-Pin RS232 cable. but the loader could not find the COM1 or COM2. I am very sure the RS232 cable is good. maybe the serial port on my cooltec was borken? any idea? |
New member Username: BurkanPost Number: 2 Registered: May-06 | Try these keys "AE F1 DF 87 F9 58 E1 55" "3A E4 8B EA ED DB BB DF" Notice that DF and EA are different |
Gold Member Username: LklivesPost Number: 2444 Registered: Jan-06 | go to ch 8282 and look for nagravison 2 dishnetwork these are OLD keys...use the new ones. keys 10---AF-0C-BD-48-D8-51-6D-DC ...Idea key 0 keys 11--- FE-44-D6-0C-A3-6E-59-42 ...Idea key 0 keys 20---3D-73-19-22-27-5D-C2-C9 ...idea key 1 keys 21---97-96-5A-0C-A5-79-27-F9 ...Idea key 1 How To Manually Enter N2 Keys For C*oolsats: ------------------------------------------------- To enter N2 keys manually you must have the C*oolsat superbin or latest bin with edit keys feature flashed to your receiver. Enter 8282 with remote as if choosing channel to open CAS Menu Use volume up and down button on remote to scroll to Nagravision ( Dish Network Provider Ident 0001 ) Use channel up and down button on remote to scroll to different Key Slot IDs and Key Slots. Enter the keys . Use the Info button for letters A-F . Press it once for A , twice for B , Etc and channel number key pad for number entries Or you can press OK and it will open a Keyboard selection type menu to enter keys. You will see the following Key Slots: 10 Key 11 key 20 Key 21 Key Post Edit: After testing I can confirm the bin editor will write to the bin with revised super bin version 1.0 and 1.1. The key slots used for N2 keys is the key slots 10 and 11. Tests of all 4 slots in various combinations reveal 20 and 21 slots have no bearing on signal decryption and correct keys must be inserted in the 10 slot for 00 key and 11 slot for 01 keys. I will note the bin will load the 00 and 01 keys duplicated within the 10 and 11 slots also appearing in the 20 and 21 slots. When key change is complete, Press Exit and confirm key change save. basically ..Idea key 0 on 10-11 lines, and Idea key 1 input into 20-21 lines. |
Bronze Member Username: JohnnerPost Number: 77 Registered: Nov-05 | Use provider id 0001 and delete the other one just by changing a DIG like 0101 to 0201 then change this keys to: --Nagravision 2 Ident: 0101 00 AE F1 0F 87 F9 58 E1 55 00 3A E4 8B AE ED DB BB DF 01 C5 6C 66 89 3A 32 D0 C9 01 24 2B F0 4F 03 68 06 92 Then I re-scaned it. |
Bronze Member Username: Eagle99Post Number: 14 Registered: May-06 | I tried this but no luck thanks anyway |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 136 Registered: May-06 | Do you change cas ident? |
Gold Member Username: LklivesPost Number: 2461 Registered: Jan-06 | yes to 0101 |
Bronze Member Username: Tetio2004Post Number: 16 Registered: May-06 | eagle99 are you still having trouble with your coolsa*t 4000 pro |
Bronze Member Username: Eagle99Post Number: 21 Registered: May-06 | yes, I tried many combinations about 00keys and 01 keys. no one works |
Bronze Member Username: Eagle99Post Number: 22 Registered: May-06 | Are the following keys correct? Key 0: AE F1 0F 87 F9 58 E1 55 3A E4 8B AE ED DB BB DF Key 1: 15 FD 84 7F A4 D1 CF E9 1C E9 58 70 2D 79 42 D9....Active |
