try unscrewing the trim if it can...or pop off the trim were the stick shift is once tht is popped off thn unscreww two screws holding the other trim down once thts dun pop off tht trim and thier should be two screws holding the radio on both sides and im sure u know were to go from thier.......dont worry bout breakin it it should pop off with sum sum sum ease
