Hatch Vs Trunk
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 331
why does a trunk car give off way better sounding bass than a hatch back?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2085
i've always heard a hatch is better.
Username: Ton
Post Number: 93
yes, hatchback is better than trunk
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2959
hatch = easy to get loud
Username: Swisher
Marianna, FL
Post Number: 111
hatch owns a trunk...no compeition at all
Username: Shman
Grandville, Michigan United States
Post Number: 153
what about folded down seats from the trunk..... didnt think of that huh?
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 730
still a hatch would be louder on the inside...than a trunk with the seats down...cuz the subs are literally right beside u...
Username: Redliner
Wilmington, Ma
Post Number: 1833
my opinion is that a trunk with seats folded down sounds the best cause no rattling(im talking firing inside)but there is no comparison in a spl evel a hatch wins easily
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 766
ya hatches are louder generally unless you do some major customization of a vehicle w/ a trunk( cutting a port through the rear deck) but vehicles w/ trunks may sound better b/c you don't hear the reverb of the subs b/c they're right behind you. its pretty much the same thing as a truck and SUV.
Username: Rovin
Trinidad & T...
Post Number: 7776
hatch RULES ! - which was 1 criteria that influenced the choice of me buying my ride a few yrs ago
& it also comes in very handy 4 hauling stuff ....
Username: Young_james
Post Number: 1462
my buddy has a 1230 with about 240wrms going to it, and I have a R with about 500wrms going to it, and his is at least twice as loud. BTW, he has a small precida hatchback and I have a corolla
Username: Shutterleftopen
Columbus, Ohio United states
Post Number: 130
yeah. hatches are basically just like SUVS. and SUVs in my opinion sound the best. trucks sound good as well. but SUV's are awesome. the only thing is with a hatchback it's easier to get your stuff stolen obviously. in a car. if your seats don't fold down, they have to put the trunk. they can just break a window in a SUV or hatchback to get in there.
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 124
Yea or you can just make a sub wall in the car facing towards the front of the car and no matter what you have itll be crazy loud. If you want it to really be as loud as possible
