Some Help Plz
Username: Splmonster
well im going for a sql setup and wanna spend abour 300-350 on subs and wanna get a nice 1200watt amp ( nine.1 kicker kx1200.1 etc )
so any suggestions?
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 75
how many subs do you want?
Username: Sw9152
Michigan
Post Number: 651
why 1200 if you dont know what sub you want yet?
Username: Ctmike
Ct.
Post Number: 493
here's 2 type r's for $225. there nice sql subs and you can run them with either of the amps you mentioned.
http://cgi.ebay.com/2-ALPINE-SWR-1242D-12-TYPE-R-SUBWOOFERS_W0QQitemZ9725698469Q QcategoryZ18803QQrdZ1QQcmdZViewItem
well id like an amp bout that so i wont need to upgrade any major electric stuff and thats about the price range on an amp im looking for, and it doesnt matter on the subs 1, 2, 3 max because i have a <<<<< 01 grand prix lol and the trunk is nice sized but not sure if i could get 3, maybe if it was a sealed box
Username: Dustin3
Tigard, Or U.S.
Post Number: 1081
i would get 2 subs in a ported box. maybe a 15 sx or xxx?
well was reading another thread and found a link and found 2 in my price range the 15 rlp and the 15 crystal comp and if the type r's are in my range which would u choose
Username: Alias747
MN
Post Number: 874
Just to let you know, your not going to be able to run 1200 WRMS on a stock alternator. So fit a HO alt into your budget. ;)
sure i will, ive seen 3000watts run off a stock alt ;), he was runnin 2 batts but ill just upgrade mine to a deep cycle, and if i do run into incredible dimming probs ill pick one up later
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2935
upgrade your batt to a deep cycle and also get a batcap 800 or a kinetic cap killer. HO alt would be best though.
you can run 30kw off a stock alternator. with that harrison lab amp lol.
Username: Sw9152
Michigan
Post Number: 655
i really like my setup. i got a rf X7 and a eclipse titanium 15". it gets plenty loud and has good sound quality in a ported box tuned to 35Hz. i have 1600wrms on a stock alt and had no problems.
Username: Rovin
Trinidad & T...
Post Number: 7764
u can run 1200wrms on ur stock alt like i did with my Mb quart raa1000 (1000wrms) & alpine 545 amp (125wrms x 4) without any problems .
But of course a HO alt is always the more sensible thing 2 do ....
Post Number: 12
off the ho alt and back on topic, what would be best?
