What do u think of this...
Username: Eseesai
Post Number: 69
i think this might me my new system it will include the following:
2 AA Assassins
1 hifonics brutes 1200 rms(i know it only produces 80% to 70% of what it says)
1 Pioneer DEH-480
What do u guys think?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2948
sounds good
Username: Matt12490
Benicia, California USA
Post Number: 794
keep your gain down. even if it does put out 70-80% of rated power, it is still going to over power them. also what size assassins?
Username: Eseesai
Post Number: 70
either some 10's or 12's cause i dont think 15's wouldn't fit my trunk?
Username: Matt12490
Post Number: 796
they dont make assassin 15's anyways.
Username: Eseesai
Post Number: 71
oh my bad i was looking at the haviocs my bad ya so either 10s or 12s what do u think?
Username: Livin_loud
Ny
Post Number: 29
Depends on how loud you want it. They should have about the same SQ, but the 12's will push more air, and cost a tad more
Username: Eseesai
Post Number: 73
ive heard nothing but good things about AA Assassins and the whole AA line up but since they are in my price range right now im going with those so what would be better in that price range if u guys dont agree?
Ny
Post Number: 30
If your going for SQ, personally I don't think you can beat em at that price. But they aren't meant to get real loud. Idk what they'd hit dB wise but you'll be able to feel them and all. You could probably pick up a single sub thats louder with a little less SQ for about the same that you would pay for both of them. So basically, it depends on what you want. If its good SQ with ok SPL stick with them, or if you want decent SQ with a bit more SPL look for a single bigger sub
Username: Eseesai
Post Number: 74
im looking for SQ and some SPL but if they are good than i think i should go with those.
what else would u recommend if i was looking for some SPL?
Username: Matt12490
Post Number: 803
just go with the assassin 12's, you wont be dissappointed. what was your previous system?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1747
maybe one arsenal, ported to 35hz, should have good sq and still get loud enough for most people, or are you gonna port the assassins, if so i would stick with those, i'd bet in a nice box those could get in the high 130 low 140 db range.
Username: Eseesai
Post Number: 75
yeah im gonna port the assassins
well this is my first system im going to install in my honda civic
i also wanna upgrade my truck system right know i have 2 rockford fosgate punch P1 10inch and a RF 2002 to power them but i think the amp is still underpowering them i hope to upgrade to one havioc or 2 arsenals
