Ascendant audio vs. soundsplinter
Username: Darrenmunsk
Post Number: 26
for a sql system leaning toward spl what would be best?
2 12" aa arsenals
2 12" soundsplinter rl-p's
also are q-ogic ported boxes any good? does tcab make reasonably sized dual sub boxes?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2845
2 arsenals.
as for q logic, i'm not to familiar with their boxes. TCAB, e-mail them and ask them about them. they make good boxes though.
or you could always attempt to make your own box. i'd do it but im busy with another intall right now.
Username: Sw9152
Michigan
Post Number: 602
makin your own box isnt difficult as long as you have the right tools. you can get a plan for a box at accelerator-pedal.com that gives you the size of each board you will need to make your box, no thinking involved. lol
Post Number: 27
i like the no thinking part, but i have carpentry skills of a quadriplegic walrus so making it myself is almost out of the question.
