New member Username: 442boyPost Number: 1 Registered: May-06 | ok i have 2 12 inch volfenhag 1000 watt dvc subs mounted in seperate boxes ok first this is my first time dealing with dvc's so how do i hook them up....my amp is a lanzar vibe 800watt 2 channel for the subs and im going to go cheap and use a 420 watt dual amp for my speakers ....by the way ...would this be enough to "fire up" a chevy astro.... im also ordering a volfenhag 1.5 farad capacitor for it to spice it up also sould it be better to buy all my cables seperatly or a kit....what gage |
New member Username: 442boyPost Number: 3 Registered: May-06 | yea its a 4 ohms dvc |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1024 Registered: Oct-05 | then hook it up to 4 ohms. use www.the12volt.com - it shows a diagram, just enter how many subs and the config. and wire it too what ur amp can handle. you can eiter wire it to 4 or 1 ohm |
Silver Member Username: NypdlapdOntario Canada Post Number: 405 Registered: Feb-06 | 4 gauge and DO BIG 3 ,,,i have a chevy astro as well and the alt is 105 amps!!! |
Bronze Member Username: MateoPost Number: 98 Registered: Oct-05 | dont get a cap. either |
