What subs would you buy if..
Username: Camarokid
Niagara falls, Ontario Canada
I have a audiobahn A2300HCT, i was running 3 audiobahn sound q 12'' in a sealed box. and i just wasnt happy with it and i blew one up... i just want to hear any suggestions you guys might have that would be louder than my 3 12's... i will go sealed/ported 3 10's 2 10's 2 15's 3 12's 2 12's anything that will be redicilously loud for what i have money isnt realy an object thanks
Username: Sw9152
Michigan
Post Number: 609
i would get the new RE XXX 18". i have not heard a new XXX but with almost 5" of excursion on an 18" it has to be very loud. you would have to go ported if you want loud.
Username: Sw9152
Michigan
Post Number: 611
Username: James1115
Ct
Post Number: 5795
if you want louder then your 3 12's look into DD (digital design) they are pricey but well worth the money.
