Bronze Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 88 Registered: Jan-06 | OK. I have 2 10inch alphasonik svc subs (4 ohms each) hooked up to a visonik mono amp (350 watts max, dont know rms). Anyway, I have a Visonik 12 inch (also 4ohms svc) sub sitting on the shelf. Is it possible to hook up all 3 subs to the amp, and make it stable? the 10s are hooked up parallel, btw. |
Gold Member Username: Young_jamesCanada Post Number: 1442 Registered: Sep-05 | Nope.....that produces a 1.34ohm load, and I'm sure that amp can't handle that. Besides, you don't want to hook up the 10's and the 12 the same time. It will probably sound like garbage. Either pick the 10's or the 12, but not at the same time. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 569 Registered: Dec-05 | sell it, buy one little amp 1 ohm stable like kicker 600.1 or orion, or audiobahn a8000t(2 ohm stable) and buy 1 or two 10 subs, you'll be happy |
Bronze Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 91 Registered: Jan-06 | hooked up all 3 subs in series configuration. Worked, but didn't hit as hard as the 2-10's so went back to that. |
Bronze Member Username: Themax99sePost Number: 12 Registered: Apr-06 | Yeah mix matching subs are a waste of time, and sound like crap. |
Bronze Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 93 Registered: Jan-06 | I dont think it had to do with the different subs, I think that it doesn't get as much power to each sub as it does hooked up parallel |
Bronze Member Username: Emdawg12345Post Number: 35 Registered: Jan-06 | http://www.rotteneggs.com/?refid=182315 mayb this will help ur problem |
Bronze Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 95 Registered: Jan-06 | WTF Does rotteneggs.com have to do with subs and amps? |
Gold Member Username: RovinTrinidad & T... Post Number: 7717 Registered: Jul-05 | that F ing guy has been spamming all over ecoustics with that F ing site !!!!!!....... |
Bronze Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 96 Registered: Jan-06 | OOOH, I LOVE TO EAT SPAM! SPAMWICH..YUMMY!!! |
