Grim
Username: Jbird
thanks can you tell me the type cord i need
Username: The_wank_artist
Post Number: 178
It would look like this. It's a USB to RS232 (9-pin) Cable. Around $15 USD.
Product Requirements
Windows 98/2000/ME/XP
CD-ROM drive to use drivers/utilities CD
Serial device with a 9-pin RS232 interface
PC with USB interface
Post Number: 179
Shoots, that's not the right cable.
Hang on and I'll try find the right one.
Post Number: 180
Here's one, but not image of the interface that would connect to the 3500.
USB to 9 Pin "D" Connector - Adapter
For Computers that don't have a RS-232 serial port, this adapter is ideal. Plug 6 ft. cable into your USB port, install software from included CD and your laptop computer can program your FTA receiver!
retails for $25.
using Google image, search 'usb pansat cable'
Username: Grimreeper
Post Number: 66
the first one will work use that and the null modem cable that came with your reciever most likly youll have to setup wich comport itll run on so itll work
