Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 149 Registered: Dec-05 | whats some good 12 inch subs to get to be used with a 500/1 slash series amp ? for like $240 and under for two |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6879 Registered: Jul-05 | kappa perfect |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6880 Registered: Jul-05 | assasian, re re |
Bronze Member Username: BudlingCali USofA Post Number: 28 Registered: May-06 | kappa perfect vq or dvq |
Silver Member Username: ReloadedMebane, NC U.S.A Post Number: 150 Registered: Dec-05 | could someone send a link to me for the assasins? the re entry level seems like it wouldnt take the power because isnthe JL underated, cant it put out more then 500wrms? so it would blow those re's right? |
Silver Member Username: Gavbo211IL US Post Number: 203 Registered: Jan-05 | JL Audio 12w3v2 |
Silver Member Username: Gavbo211IL US Post Number: 204 Registered: Jan-05 | or the 12w3v3 |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 594 Registered: Dec-05 | type r and CVR |
Silver Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 191 Registered: Apr-06 | treo tsx |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 2136 Registered: Dec-05 | type r |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2023 Registered: Feb-05 | link to the assassins is www.ascendantaudio.com nice subs from what i've heard. you'll prob see 600 from that JL amp if you power it properly and wire at 2 ohms. |
