Truck off, system thumpin'
Username: Dub_c
Post Number: 35
I was wondering if anyone knew how long it takes for the battery to go all the way down? AND what can I do so I can listen to music longer with the engine off? Besides a second battery.
Username: Nypdlapd
Ontario Canada
Post Number: 386
DON"T LISTEN WHEN ITS OFF^^LOL J?K
I have the same question!!!
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 279
a yellow top dead cycle helps when the car is off more than a stock battery but its better when car is started so u get more power from the alternator
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2011
its all dependant on the battery or batteries you are using and the watts/current you are pulling from them.
don't know if theres any way to calculate it out.
Username: Dub_c
Post Number: 36
Which optima battery would be good to get, the yellowtop or the redtop?
Stockbridge, GA USA
Post Number: 2029
theres a long thread in the ACC section on red vs. Yellow.
Username: Dub_c
Post Number: 37
Whats the bluetop for then? I can't find that threadin the acc. forum.
Username: Fiber
Post Number: 211
I think bluetop is marine batteries I was lookin at them yesterday at autozone
Username: Dub_c
Post Number: 38
Autozone has optima batteries?! How expensive are they there?
Username: Rideredder
Cornell, IL USA
Post Number: 317
I always run my remote wire so that I can listen to the radio (without the subs) on ACC. And, letting your car idle for long preiods of time isn't good either. I learned that the hard way, a leaking radiator and cracked water pump later.
Username: Johnny619
San Diego, CA
Post Number: 139
Optima run from 129.99 to 190.00 at autozone i believe. i brought one for 185.00
