OT, other thread wont work. wiring to 2 ohm and 1 ohm..
Username: Rollout4877
Kent, Ohio USA
Post Number: 29
http://img242.imageshack.us/img242/2078/kickerohms9yr.jpg
thats how i have my 2 dvc 2 ohm speakers wired right now. do u think i can wire it to 1 ohm? i dont think i can wire it in a series because my box is chambered.
Kent, Ohio USA
Post Number: 30
btw i have a boss power drive 3000 watt amp
Kent, Ohio USA
Post Number: 31
going to two dvc 2 ohm kicker l7's
Username: Van_man
Boston, MA
Post Number: 145
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?view =all
Username: Winn
Santa Ana, California US
Post Number: 112
You can NOT wire 2 DVC 2 ohm to 1ohm, it's impossible.
Username: Tjmutlow
Post Number: 1998
that is a 2 channel, on 1 sub run + to + and - to -, then to the terminal cup inside the box, run that amp 1ohm stereo stable.(per channel)
Username: Goatin
U.S.A
Post Number: 972
Is that amp brideable? if it is bridgeable to 2 ohms I would suggest bridgeing it it will sound a bit better.
Kent, Ohio USA
Post Number: 32
yeah its bridgable. but its only 2 channels. how can i bridge it?
Username: Goatin
U.S.A
Post Number: 988
If it is bridgeable it should say right on the amp and look something like
(+)___bridge___(-)
Where you plug in the speaker wires
Or if it does not say then on your speaker outs you will see the Left(+)(-) Right(-)(+) you will want to wire the (+) from the left and the (-) from the right.
Left(-)(+)____Right(-)(+)
Positive to sub___Negative to sub
Username: Juliob
Santo DomingoDominican Re...
Post Number: 583
be sure it is 2 ohm stable bridged
