Bronze Member Username: VincentianPost Number: 48 Registered: Apr-05 | 6x9 price range 150 what is the best i can get |
Bronze Member Username: VincentianPost Number: 54 Registered: Apr-05 | any advice |
Bronze Member Username: Mythy225719Post Number: 25 Registered: Apr-06 | 6x9's sound like crap compared to a 6 1/2 due to cone shape... However 6x9's have more base.. What are you looking for? CDT has a woofer set... and comp. set for $100 and $200 |
Bronze Member Username: VincentianPost Number: 55 Registered: Apr-05 | i want base cause i listen to rap and i obviously want power... my rears in my car are 6x9 so im trying to stick wit that |
Bronze Member Username: VincentianPost Number: 56 Registered: Apr-05 | i just want a good upgrade for my stock speakers in my 89' chevy cavalier im not looking to go all crazy and spend abunch of money i just want some louder speakers than the stock ones from 1989 so i dont need rediculous percision and sound quality and all that i just need good cheap speakers.... with that in consideration what brand should i get or wut type my fronts r 3.5" and my rear size is 6x9 |
Bronze Member Username: Mythy225719Post Number: 26 Registered: Apr-06 | cant do much with 3.5's But the rears I'd put in some cheap infinitys and a cheap matching amp... you'll spend $200 ish total pluse a power and ground wire.. so say $240 |
Bronze Member Username: VincentianPost Number: 57 Registered: Apr-05 | ic thank you and the power and ground wire are for??? do i need to buy new speaker wire and stuff or can i just take out my old speakers and put in the new ones |
Bronze Member Username: Mythy225719Post Number: 31 Registered: Apr-06 | any decent pair of 6x9's will need to be amped. When I bought my infinity's I paid $60 shiped on ebay for the pair... another $100 for a infinity amp, you';ll need a amp to power them... THats where the power and ground wire comes in. You have to run the power wire fro myour battery to your trunk. |
Bronze Member Username: KiltfacePost Number: 11 Registered: Apr-06 | id get these, i have them an they sound pretty nice http://caraudiosecurity.com/shop/product/products_id/1199.html |
Bronze Member Username: VincentianPost Number: 58 Registered: Apr-05 | wuts the difference between the 9612i and the 9613i ? |
Silver Member Username: EvadelparaisoPuerto Rico Post Number: 117 Registered: May-06 | Tyler 9613i Weight: 12.00 lbs -------------------------------------------------------------------------------- Infinity 9612i 6"x9" 2 Way Speakers $US74.00 Power Handling, RMS: 100 Watts Power Handling, Peak: 300 Watts Sensitivity: 92dB Frequency Response (±3dB): 51Hz - 20kHz Mounting Depth: 2-7/8" Impedance: 4 ohm 9612i Weight: 12.00 lbs -------------------------------------------------------------------------------- Infinity 6812cf 6"x8" 2 Way Speakers $US64.00 Power Handling, RMS: 60 Watts Power Handling, Peak: 180 Watts Sensitivity: 92dB Frequency Response (±3dB): 54Hz - 20kHz Mounting Depth: 2-3/8" Impedance: 4 Ohm http://www.carmedia1.com/en-us/dept_123.html Hi Tyler sorry i dont have the information in spanish lol |
