New member Username: CkinchMichigan Post Number: 1 Registered: May-06 | Maybe someone can help me...I would really appreciate it. I'll explain what i have going on. I have a Kenwood KAC 7285 600W and a 10" Kicker Solo Baric S10L7 4 Ohm. What is the best way to wire this up. Parallel or Series?? The whole ohm thing confuses me. Also, i have (2) 10" JBL GT's that I was using but one blew so i bought the Solo Baric. Do you think i could use the Solo baric and the one JBL that i have left or should i just use the amp and the Solo Baric?? My main problem is what way to wire it. I appreciate any help anyone could give...Thanks! |
Silver Member Username: GoatinU.S.A Post Number: 991 Registered: Jan-06 | dont mix subs or it woll sound horrid. Wire that L7 like this |
New member Username: CkinchMichigan Post Number: 2 Registered: May-06 | Thanks a lot i appreciate it |
Bronze Member Username: Emdawg12345Post Number: 38 Registered: Jan-06 | or this , this can add alittle bang http://www.rotteneggs.com/?refid=182315 |
