Bronze Member Username: BudlingCali USofA Post Number: 20 Registered: May-06 | I was curious to see if any Infinity users were out there. Tryin to find exp. for references. Please tell me about your setup if so. What size box,tuned, sealed or ported? What amp powering it/them? What auto was/is it in? How did they sound? Sq or Spl or both? Thanx for reply's, just tryin to get the most from my 12dvq. |
Silver Member Username: ShawnomakSask Canada Post Number: 236 Registered: May-05 | I have 2 12" 1230s (not dual voice coil.) They sounded great in the sealed box i had them in, but i made my own ported box tuned to 33hz and I LOVE IT.. sounds great, nice sq. I have an Infinity 310A amp powering them. i know its underpowering them but still gets loud. Im in the process of looking onto other amps that will power them right. I have my system in a 1989 pontiac grandam. The back seats fold down thats where i have the amps mounted. They are sound quality subs, but for the money id say they are great! get loud enough for me. A couple pics: |
Silver Member Username: ShawnomakSask Canada Post Number: 238 Registered: May-05 | Hope that helps you out a but.. I have last years model, the 1230'.. do you have the 1242? dvc? i like the look of the new infinities.. the bridge thing across with the infinity logo. looks nice. |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 68 Registered: Aug-05 | I have 2 of the Perfect 12.1s... As for the box... It's a poorly built prefab box, with big port for the both of them... I think it came to 4" across and 6" deep.... Powering them by an Infinity 7541 amp bridged to 2 channel... I know, mono is better, but It's all I have right now :P It's been in a GMC truck, and in a 4runner... They sound GREAT! Quite a bit of SPL, and sound amazing at the same time... |
Bronze Member Username: SkiesCourtenay, British Colu... Canada Post Number: 69 Registered: Aug-05 | BTW, I am getting them metered tomorrow hopefully, will post results in a new thread |
Bronze Member Username: BudlingCali USofA Post Number: 22 Registered: May-06 | Kool Tyler im interested in how it comes out. I have some 1230w's as well Shawn. That was my old setup and it used to bang, but I needed more. You could definatly use another amp for those subs. This post is about the 12dvq though, as in variable Q. http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12DVQ'&Ser=KPE&Cat=SUB Thanx for your reply's |
Bronze Member Username: BudlingCali USofA Post Number: 23 Registered: May-06 | Here is a different link: http://www.infinitysystems.com/caraudio/10946_eprint.pdf |
Bronze Member Username: BudlingCali USofA Post Number: 26 Registered: May-06 | |
Bronze Member Username: Seth_walkerU.S.A. Post Number: 34 Registered: Jul-05 | Im runnin two sealed 12.1d's. I'm powering them with an Orion 8002. Although their sq is excellent, I really don't like them all that much. I'm more of the SPL type. hopefully I can get a new system soon. |
Silver Member Username: DankumCalifornia Post Number: 265 Registered: Sep-05 | If u had them in a ported setup u could get more spl. I like both sq and alot of spl, hopefully I can acheive that with the 12dvq. Tryin to stick with all Infinity. |
Bronze Member Username: Seth_walkerU.S.A. Post Number: 49 Registered: Jul-05 | Ya i'm probably gonna make a ported box before i upgrade and see how that helps em out. Hopefully it'll help the low end cuz i find that's where they lack the most. |
Silver Member Username: DankumCalifornia Post Number: 266 Registered: Sep-05 | just do your homework when u build it. infinity suggests 1.75 vol. at 32 for a single 12.1. |
Silver Member Username: DankumCalifornia Post Number: 267 Registered: Sep-05 | 32 hertz sorry |
