Bronze Member Username: Rollout4877Kent, Ohio USA Post Number: 28 Registered: Apr-06 | i have 2 dual vc 2 ohm subs i need to wire to one or 2 ohms. people keep sending me this website http://www.the12volt.com/caraudio/woofer_configurations.asp but my box is chambered so i cant wire in a series. please can someone show me a diagram how to wire it soon so i can do it pronto. |
Silver Member Username: WinterfreshpimpChisago, MN America Post Number: 236 Registered: Mar-06 | wire the subs up to 4, the wire the box down to 2 with the terminals |
Silver Member Username: Demon_prideCrowder, Oklahoma USA Post Number: 119 Registered: Oct-05 | Drill a hole through the chamber wall and run your wire through it and only use one terminal. Be sure you seal up the hole good though. |
