Gold Member Username: RzarectorCoquitlam, Bc Canada Post Number: 1167 Registered: Dec-04 | how do you find out if something is cea rated? is tehre a listing somewhere |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 576 Registered: Dec-05 | good question |
Gold Member Username: Mikechec9Post Number: 2384 Registered: May-05 | There will be a stamp: "Amp Power Standard CEA-2006 Compliant." http://www.ce.org/Membership/Directory/default.aspx?alpha1=r |
Gold Member Username: RzarectorCoquitlam, Bc Canada Post Number: 1170 Registered: Dec-04 | thanks mike.. so if a company is not in compliance with cea will they usually give phony ratings? |
Gold Member Username: Mikechec9Post Number: 2388 Registered: May-05 | No. That's not necessarily the case at all. It's just a secure feeling to know when the company/amp does comply. It's best to know by experience or knowing someone with the actual amp. Forums are good in this regard. It's not like how a speaker "sounds." I mean, either it produces its rated power or it doesn't. |
