I Need A 1200w Amp
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 225
Need An Amp 2 Power A 10 SX For Now an Later Ill b Usin The Amp 2 power My 15 Sx Dont Wanna Spend Over $250
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6716
A decent 1200 watt amp will cost around 300+ u better look at Hifonics.lol
Username: Mtite_dabeast
Post Number: 23
A1300HCT... This amp is 1 ohm stable at 1200w rms (so ive heard)... Less than $300 on ebay. Find a good auction, and u mite get it for less than $200. Good Luck.
Username: Rovin
Trinidad & T...
Post Number: 7554
if its only 1 SX then
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
which i own - read my review ^^^ on it .....
Username: Juliob
Santo DomingoDominican Re...
Post Number: 542
lanzar optidrive 1400d is a good deal on ebay
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 82
still gto that orion 1200d going for 250 shipped if interested...
Username: Fandim
Reno, Nevada United State...
Post Number: 939
You should get a Hifonics brutus 1605(or 1606 now I guess). It'll put out about 1200 real watts.
Post Number: 226
i want more like jbl 1200 kicker 1200 or orion 1200 i found a jbl 1200 on ebay for like $144 wit shippin but theres like a day an some for it 2 end
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2790
That bp1200.1 is a great amp lil amp for the $...it will give you 1300wrms+ w/ a good electrical system.
But if you are going w/ a ported box, i highly recommend getting a Harrison Labs Fmod for the amp. (SSF)
Username: Daytonacustom
Forrest City, Arkansas USA
Just a suggestion but i live in Forrest City,AR and Wal Mart has 1200 Watt X-Plod's for about $150
Username: Sw9152
Michigan
Post Number: 548
the 1200w sony will prolly put out real 500w.
Post Number: 6855
if that, i was thinking closer to 300
Post Number: 6856
https://www.ecoustics.com/electronics/forum/car-audio/221182.html
