Bronze Member Username: GravytrainCanton, Michigan USA Post Number: 16 Registered: May-06 | has anyone seen the new JBL A6000GTI amp...i think its a bit excessive... ...here are the specs... Power Output 2600 Watts RMS x 2 channels at 4 ohms and less than 1%THD+N 8110 Watts RMS x 1 channel at 4 ohms, 14.4V supply and less than 1%THD+N 7400 Watts RMS x 1 channel at 1 ohm, 14.4V supply and less than 1%THD+N Signal-to-Noise Ratio 65 dBA (reference 1 Watt into 4 ohms) Dynamic Power 6854 Watts at 4 ohms Effective Damping Factor 6.39 at 4 ohms Frequency Response 10Hz to 270Hz (-3dB) Maximum Input Signal 8.5V Maximum Sensitivity 250mV Output Regulation .2 db at 4 ohms Dimensions (H x W x D) 6-1/2" x 29-3/8" x 23" MSRP U.S. $ $6000.00 WHAT SUBS WOULD YOU RUN WITH THIS??? |
Bronze Member Username: Jpio24Schaumburg, IL Post Number: 44 Registered: Mar-06 | big ones |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6853 Registered: Jul-05 | almost any spl sub could be ran with this Mt oz power dd 9900, etc its not even the most powerful |
Silver Member Username: Nnnnick_bWeddington, Nc Usa Post Number: 698 Registered: Jan-05 | http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=7 &family_id=24&item_id=105829&locale=en_US RF t15kw, not sure if this is the most powerful production amp, but it must be close. |
Bronze Member Username: Troy81Tavernier, Fl Us Post Number: 89 Registered: Mar-06 | yes its def close id say haha |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 568 Registered: Dec-05 | kicker solo X |
