Memphis 1100d
Username: Troy81
Tavernier, Fl Us
Post Number: 50
ive heard a lot about this amp, ive heard its amazing, and it wins alot of comps...... how amazing could it be, its 1100rms.... btw i ordered one
Username: Tjmutlow
Post Number: 1981
its a nice amp...
Username: B101
Queen City, NC USA
Post Number: 2737
its a killer amp, and is underatted too... I keep see u askin the same questions. NICE AMP especially for the size!
Username: Troy81
Tavernier, Fl Us
Post Number: 67
will it be louder then the MASSIVE 1500d i already have?
Username: Troy81
Tavernier, Fl Us
Post Number: 83
bumper nickel
Username: B101
Queen City, NC USA
Post Number: 2744
it will be TRUE POWER! it will give u more than its rated at!! Your MASSIVE 1500 might do 1000rms.. I know Memphis is the better company!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 567
better built too
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2873
i highly doubt you will be able to tell much difference in the sound by swapping from the massive 1500w to the memphis 1100w.
Username: Troy81
Tavernier, Fl Us
Post Number: 92
why is that marshall
Post Number: 2874
that massive should put out at least 1000-1100wrms...the memphis will do ~1200.
you wont really be able to notice a ~15% difference in power. (it may be ~0.5dB different)
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1168
i doubt the memphis will do 1200... it only has 80 amps of fusing
Username: B101
Queen City, NC USA
Post Number: 2746
my prd1000.1 had 40X4= 160a and the mc1100 puts out more than rated!
either way, he is not going to gain much from the switch, maybe except sq, efficency, and life of equipment!
Username: Troy81
Tavernier, Fl Us
Post Number: 93
well if you use that it should only put out 800 watts. so basically, youre wrong
Username: Lexuscoop
Phx, Arizona
Post Number: 1471
um... i wouldn't be starting stuff with B... he knows what he's talkin about...
