Bronze Member Username: Rollout4877Kent, Ohio USA Post Number: 20 Registered: Apr-06 | ok i have 2 12 inch kicker l7's dvc 2 ohm subs with a boss 3000 watt amp. my friend hooked them up wrong and i took them into to get done professionally and i think i heard him say he wired them at 4 ohm. and now its not nearly as loud as it was. b4 it would rattle my rear view mirror until it feel completely down. these r good subs and it should be alot louder than it is right now. ne pointers? and also is there a way i can wire them at 2 ohms without wiring them in a series because my box is sealed and has 2 separate chambers |
Silver Member Username: Sw9152Michigan Post Number: 546 Registered: Feb-06 | yes |
Bronze Member Username: Rollout4877Kent, Ohio USA Post Number: 21 Registered: Apr-06 | http://img62.imageshack.us/img62/1764/2ohm6qq.jpg is this a good way to wire at ohms? |
Silver Member Username: Sw9152Michigan Post Number: 547 Registered: Feb-06 | |
Bronze Member Username: Rollout4877Kent, Ohio USA Post Number: 22 Registered: Apr-06 | so i would only use one channel? |
Bronze Member Username: Rollout4877Kent, Ohio USA Post Number: 23 Registered: Apr-06 | bump |
