Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 331 Registered: Nov-04 | What size ported box would you guys recommend for the best SQL from these 2 12" woofers getting 600 watts. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9719660159%26&sspagename= STRK%3AMEWN%3AIT%26 |
Gold Member Username: RovinTrinidad & T... Post Number: 7696 Registered: Jul-05 | um it those specs in ur link r correct >>>>>> Enclosure Recommendations Sealed = 1.0 cuft optimum 0.70ft^3 to 1.25ft^3 (Net Box Volume) Ported = 2.0ft^3 (Net) tuned to 28Hz 4" round port, 14.5" length --or-- 1.75 cuft with 3" round port 9.625" depth well then there is ur answer ^^^^^^^...... |
Bronze Member Username: Emdawg12345Post Number: 26 Registered: Jan-06 | http://www.rotteneggs.com/?refid=182315 of u can just get this one |
