Which Amp/Sub Should I Get
Username: Nruzicka
Post Number: 21
Ok here is the deal i want to get some new subs and im not sure what to go with i dont want to spend more than $150 each, i have one Alpine m350 that pushes 350 rms and 700 max, and i need to know if that will be fine or if i need another amp? also i have a 94 grand cherokee and do i need an extra battery for it or a heavy duty alternator for it? thanks
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 186
http://cgi.ebay.com/ALPINE-SWR-1242D-12-DVC-Subwoofer-Type-R-Car-Sub-NEW_W0QQite mZ9719693786QQcategoryZ18803QQrdZ1QQcmdZViewItem
you can buy to alpine type 'R's for 140 a piece on ebay.
ive heard they have excellent sq
Post Number: 187
http://cgi.ebay.com/PHOENIX-GOLD-X600-1-Xenon-600W-Mono-Amplifier-NEW_W0QQitemZ9 719569521QQcategoryZ18797QQssPageNameZWD7VQQrdZ1QQcmdZViewItem
this pg amp will push those subs 300 rms each and itts also not tht much
Username: Juliob
Santo DomingoDominican Re...
Post Number: 578
mb quart raa and two type r dual 4 ohm
