Dynaudio 360?
Username: Ogduncan
Post Number: 40
would the dynaudio 360 system with 2 idq 12's be a good setup? I found it for 799 which isnt too bad. Or is there something else better thats cheaper or around the same price.
Username: Virulentv
Post Number: 53
where on earth did you find it for that price man ? let me know i am looking for DYNs too brother.
Username: Ogduncan
Post Number: 41
i see that the speakers say 200watts continous. does that mean i need a amp that does 200X2@4ohms? Also is it okay if i run them off a 270X2@4ohm amp(2500xxk)
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2022
if they are rated 200 RMS, an extra 70 watts won't hurt, as long as its clean power. clipping speakers will really screw them up, more so then subs, they aren't as tollerant.
nice amp btw.
Username: Ogduncan
Post Number: 42
i was thinking about the butler amp that puts out 175X2@4ohms as well. do you think it would sound better on that than the arc. I know there totaly different the butler having the tube desighn
