Not getting PPVs
Username: 31415926535
I have an Ariza750CX.
I have the 272 bin.
I have the newest keys.
My satellite is pointed at the correct place.
I'm using the satellites Echo7 and Echo3.
Recently, ALL the PPV channels aren't working. It says 'no signal'. It's strange because ONLY the PPV channels stopped working and nothing else. BTW, my PPV channels are the Dishnetwork PPV movie channels. What can I do?
Username: Grimreeper
Post Number: 57
try 2.73 bin it has auto tp and autoroll on/off
Username: Steven_man
Post Number: 14
I have fortec Star LC NA. I was getting all the PPV channel(dish Sat 110) and couple weeks a go it stoped. Now it says Scramble channel. All the other channel are working fine. I have updated to latest 060402.bin file and have the correct code on it. Anyting I can do to get the PPV Channel back. Thanks. Steven
Username: Moyn
Do anyone know how to unlock any PPV's channels "please help me"
Username: The_wank_artist
Post Number: 59
You need to scan the tp's
channels been moved all over the place and a shiz load of them got moved on the 28th.
Read this link.
https://www.ecoustics.com/electronics/forum/home-video/219758.html
Username: Evadelparaiso
Post Number: 30
JUST TO SAVE YOU NEWBIES THE TROUBLE, ENTER C56C KEY IN BOTH 00 AND 01. WORKS FOR ME. 9E5B NOT NEEDED. I BEEN TRYING OUT FOR LAST 1 HR UNTIL I FIGURED IT, GOSH. YEAH. PANSAT 100E 2300 2500
Louis post this. But for me still function the last keys in nagravision 2
Idea Key 0:
9E 5B 7A 77 C0 FE 91 CA
4D 2A DC 33 D4 CD E3 75
Idea Key 1:
C5 6C 66 89 3A 32 D0 C9
24 2B F0 4F 03 68 06 92
Username: Anai
TX United States
Post Number: 51
I already checked the keys, as I don't have the bin, so I put them manually, everything is working but the ppv/s I already did a blind scan and it's the same (no ppv). Suggestions needed!
Post Number: 64
Which ppv channels?
list a few if you can.
Username: Anai
TX United States
Post Number: 52
503, 4,5,6,7,8,10,12,13,14,15,
16,18,20,21,22,23,24,25,26,27,
28,29,30,31,32,33,39,
I know, it was easier to write the ones that are working. je
Username: Rupinder
i have microyal 1200, i cant see any pay per view on 110, what should i do
Post Number: 72
From http://ekb.dbstalk.com/dishlist.htm
April 28 Transponder 29 at 110° (E*6) was moved to transponder 8 (E*8). This affected channels 100, 503, 506, 507, 510, 516, 521, 523, 524, 9927, 9929, 9998
If you go to channel 503, what tp does it read? 12632 ir 12326??
Username: Dafee99
if you have an updated bin with the working keys (C5 6C 66 89 3A 32 D0 C9
24 2B F0 4F 03 68 06 92), did a blind scan, and still missing channel, try setting default keys before entering the new keys. AS SAID in the previous post 9E 5B keys are no longer active... so dont bother inputting those.
Username: Anai
TX United States
Post Number: 56
says 12632 MHz(V)
Post Number: 74
DUDE!!!!!!!!!!!
Those channels have moved transponders!!!!!!
You're killing me.
Check out this link...
You've got some work to do, sat scan and all the channels will be there, but not in the same order you had them in before most likely.
But they're there.... So is the truth... it's out there!!
Post Number: 75
OH, I forgot. The old channels will be there too, but they won't work. 503 is on 12326 now, and it will be in your channel list but it won't be named the same. probably just 'PPV' or something like that. The 503 you used to have on 12632 will be there also, but as you can see it isn't working. Might as well erase that one.
Username: Anai
TX United States
Post Number: 59
jaja. that's for me?
Ok, what I did, is went to favorites, look for all the ppv's and movie channels and put them together in favorite 5, but I want them the way they were, just because I was used to that.
btw, no estoy tratando de matarte. jajaja
Post Number: 77
You're going to have to find a new channel list and channel loading software. You'll have to get it from another site, the software.
As for the channel list, you can make one yourself or try find one pre-made.
Y sé que usted no trata de matarme.
Username: Anai
TX United States
Post Number: 61
ok, Now I have another problem, I cannot connect my pansat to a pc, cause I don't have one, I work with MAC, so I have to check who can help me here in the city.
Post Number: 78
Sorry babe, I'm nowhere near texas.
WILL SOMEONE PLEASE HOOK THIS LADY UP WITH A PC!!!!
Username: Irka
Winnipeg, Manitoba Canada
How do we get the xxx channels back
Username: Anai
TX United States
Post Number: 62
jaja THANKS TYLER YOU'RE ALMOST BECOME MY HERO!!
