New member Username: Spaceace409Post Number: 1 Registered: Apr-06 | I search the forum but cant seem to find the answer unless i overlooked it. I have a Dish 500 with a DPP Twin lnbf and 2 DP322 receivers. I want to add the Pansat 3500SD to the setup but dont know what is needed to accomplished this. Is there a suggestion or a pic of the setup so I can see what I am missing? I was looking into getting a DP44 but at $200 I was like "DAMN". Any suggstion would be more than welcome. TIA |
Gold Member Username: LklivesPost Number: 2108 Registered: Jan-06 | U need to do a search...we had a lengthy discussion in 1 thread here about DPP LNB's and receivers..seperators must be removed...and power comes from receivers staying on..obviously U will need DP switch for more receivers, but if I remember right U cannot use any switches.. |
Gold Member Username: LklivesPost Number: 2109 Registered: Jan-06 | U got lucky ...info is all here about DPP and receivers,but I dunno about 3 receivers..read this link and the links in the link and U will get your answers! https://www.ecoustics.com/electronics/forum/home-video/211802.html |
Bronze Member Username: Rsmc73Post Number: 13 Registered: Mar-06 | This is the switch i use I have 110 into 1 119 into 2 and 91 into 3. I have cool sat 5000 on receiver out 1 and i have the dish receivers on sat out 3 and 4. Works for me. |
Gold Member Username: LklivesPost Number: 2111 Registered: Jan-06 | Thats a DP 34 switch...but do U have Dish Pro PLUS LNB's?...not just Dish Pro! |
Bronze Member Username: Rsmc73Post Number: 14 Registered: Mar-06 | No just dish pro twin for dish 500. I know its not the lnb he ask about just saying what works for me. |
New member Username: Spaceace409Post Number: 2 Registered: Apr-06 | LK Thanks for the quick reply. I have a 322 that requires 2 input. If i remove the dpp seperator wont i still need 2 input to the 322 receiver? rsmc73 I have a dp34 but was told it wont work with DPP Lnbf |
Gold Member Username: LklivesPost Number: 2120 Registered: Jan-06 | NO...read the link...thats why I hunted and posted it for you!...now no need to ask any questions... |
New member Username: Spaceace409Post Number: 3 Registered: Apr-06 | Maybe I am missing the key here. I read the link twice and in that link was another link that i read twice aswell. It state that i need to remove the seperator fron the dpp lnb line. on the back of the dp322 receivers i have it has 2 input (Sat1 and Sat2) which is being fed by the seperators. Am I suppose to run 1 cable to the pansat then from the loop thru run a cable to either sat 1 or sat 2 on the back of the DP322 or do I add a splitter in place of the seperator? |
Gold Member Username: LklivesPost Number: 2123 Registered: Jan-06 | there is another technical link within the link to...read it...and NO splitters ever with DSS..we have no more info than already provided U... |
New member Username: Spaceace409Post Number: 4 Registered: Apr-06 | I read the threads and i saw one stating to remove the DPP Seperator from the back of the DPP322 receiver and add the pansat 3500SD and it should work. But my question is If I remove the DPP Seperator then on the back of the DPP322 how will i feed the 2 input that says SAT 1 and SAT 2? Where Do I connect the cable to the ird if i remove the separator? |
New member Username: QutyPost Number: 1 Registered: Apr-06 | I setup 110, 119, and 61.5 as LK's diagram above, except that I used the Pansat 2700A instead of the Pansat 3500S. It works. Note: It seems like you need to have a DishNetwork's receiver also hooks up (to power the Dish Pro Plus LNB which has an internal switch). |
New member Username: DuckcowPost Number: 2 Registered: Apr-06 | I think I killed my 3500sd. I loaded a wrong bin and the device shut down with no power. help. thanks |
Gold Member Username: LklivesPost Number: 2147 Registered: Jan-06 | NO help for thread HIJACKERS like U...go look at the subject of this thread!...U and other rude people like U, are the reason things are impossible to find here.. |
Bronze Member Username: ContiPost Number: 42 Registered: Feb-06 | LK, The setup is exactly like above - 148 was connected to the the DP Plus. How should the diseq switches be set? Also I lose signal after a few minutes. Help LK. |
Bronze Member Username: ContiPost Number: 43 Registered: Feb-06 | LK, I need ur input for the above problem. I have good reception until adding 148 to the DP plus. I lose signal after a couple of minutes. I have 110 at diseq 2, 119 at 1 and 148 at 3. Is this the correct setup. I have all sats as standard (like prior to adding 148). I need some direction and help. Could someone please chime in. Thanks! |
Bronze Member Username: ContiPost Number: 44 Registered: Feb-06 | If 119 is 1 110 is 2 Is 148 -> 3 ??? |
Bronze Member Username: ContiPost Number: 45 Registered: Feb-06 | With dishpro plus and a dishpro hookup, must the 22Kz switch be on ? |
Bronze Member Username: ContiPost Number: 46 Registered: Feb-06 | Anyone with the antenna setup for the above 3 sats 110, 119 and 148 ???? |
