Bronze Member Username: Uback007Post Number: 97 Registered: Mar-06 | As many of you know, I am looking at different integrateds and receivers and on the NAD website there is a newly released version of the of the C320BEE called the C325BEE...Anyone know when I can get my hands on one of these and if so, how much is the list? |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 1249 Registered: May-05 | Find your nearset dealer and ask them. They'd know better than anyone else. http://www.nadelectronics.com/dealers/index.htm |
Bronze Member Username: Uback007Post Number: 98 Registered: Mar-06 | I've called 2 and they have no clue that it was even released. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1361 Registered: Sep-04 | My understanding is that it is quite imminent, maybe a few weeks away. Regards, Frank. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1362 Registered: Sep-04 | Oh, and it'll be around the same price as the outgoing model. Regards, Frank. |
Silver Member Username: Unbridled_idChicagoUsa Post Number: 165 Registered: Mar-04 | I wonder when they will update the rest of the stereo line. I assume it should be by years end, I think both audio and video will go with the 5 at the end XX5... I am anticipating the new cdp and hope it is a step up from the c542. |
New member Username: Daniel_canadaCanada Post Number: 10 Registered: May-06 | Looking to NAD's website, the list the specs the same as the 321bee, but they say it's more powerfull. Anyone know what was changed? |
New member Username: AtexPost Number: 3 Registered: Apr-06 | Here's what they say they changed: he C320BEE and its predecessors has been the benchmark for budget amplifiers for 30 years now, having won every award in the Hi-Fi industry several times over. Making the C325BEE better than the C320BEE was a tall order! By "trickling down" several innovations from NAD's new state-of-the-art Masters Series products has resulted in the C325BEE having even less distortion, less noise, and a more detailed rendition of the musical recording. New DC Servo eliminates sound colouring capacitors in the signal path. This improves musical detail and eliminates harmful loudspeaker 'offset'. Patented distortion canceling circuit uses both feedback and feed forward to reduce distortion and improve amplifier stability. Highly optimised circuit layout further lowers internal impedance, improves grounding, and eliminates subtle magnetic distortions. Lower noise and distortion, and improved channel separation are a direct result of this optimisation. Surface mount (SMD) technology shortens signal paths and lowers distortion in NAD's proprietary Class A gain modules. BEE Clamp improves HF stability when driving difficult speakers. Volume Control has minimum volume cancellation circuit to increase attenuation by 10dB. Tone controls are hand trimmed for perfect response characteristics. A new idling current circuit is more accurate with less unit-to-unit variation. More rigid chassis has improved mechanical integrity. MP Input for easy connection of iPod, MP3 and other Media Players employing 3.5mm headphone sockets. |
Gold Member Username: NuckPost Number: 2575 Registered: Dec-04 | If the unit is quieter and has more power(nothing wrong with that), it's a winner. |
