Can someone tell me what a "bin" is?
Username: Ariza
i know how to put in new codes
but all this "bin" talk
can someone give me the whole nine yards on this?
Username: Lklives
Post Number: 2264
bin is short for binary...consisting of 2 things..binary codes are written into a file which can descrambled encrypted signals..so a bin is a type of file..
Username: Hardrockstriker
Post Number: 13
A *bin*ary file is the actual program (think of it as a computer's operating system) that your receiver runs on. The bins are continuously being rewritten by the dss community to add features, fix bugs, etc... You can upgrade to a newer bin (which exists as a single file) by downloading it to your receiver, usually thru a serial cable hooked from your computer.
Username: Ariza
"usually thru a serial cable hooked from your computer."
okay that stuff is way too complex for me lol
do you guys have the codes to get the hbo/sho time channels back?
Username: Ariza
actually
is it true that the ariza 700 hooks up to a usb cable?
Post Number: 14
Ariza 700 has a serial port just like most FTA receivers - no usb port. You will need a USB-to-serial converter as well as a serial cable. But the converters are a pain in the a55 to use, so you're better of hooking into a computer with a built-in serial port to save you grief. Also, some receivers use a nullmodem cable and some straight-thru. Make sure you get the correct one or you might have to jtag your reciever.
