PPI Art ro PPI Power Series for Focal Components
Username: Bdonkersgoed
Ontario Canada
Post Number: 200
Can anyone tell me which of the following two amp series are considered the best for SQL?
- PPI Art Series
- PPI Power Series
I already have an Ax400 for my Focals, and my friend is considering one as well (or a Power Series) for his focals.
Thanks,
Bryan
Username: B101
Queen City, NC USA
Post Number: 2704
u cant go wrong with ANY PPI amp for SQ! period! but I would say the ART series... :-)
Ontario Canada
Post Number: 201
Thanks for the reply!
So, it looks like Art--1, Power--0
I believe that the Art Series is from the early 90's and the Power is fom the late 90's. I guess older is better in this case? I know that the new PPI stuff is supposed to really suck.
Thanks,
Bryan
Username: Carguy
Post Number: 5517
Actually the new PPI amps aren't that bad.
If you had a choice, go for the Art series first, then the power.
Take a look at PC series too (designed and made in US, just like Art). They're very good for components.
Ontario Canada
Post Number: 202
Actually, I think it was a PC series that he was looking at . . . I was thinking it was power.
The amp is a PC2600.2
Do you know anything about this amp? Do you also know where we could find specs? He needs it to power a set of Focal Polyglass Components I believe.
Thanks,
Bryan
Username: Carguy
Post Number: 5521
If he can get that amp at a good price, he should jump on it. I have both Art and PC series, and it is very hard to distinguish be ear.
Both great amps.
