OT- box
Username: Anthony1
Post Number: 59
Does anyone know where i could buy a box for a 15 inch sub tuned in the low 30's? I really dont have time to make one so this isn't an option.
Username: John_wash
Nashville, Tennessee
Post Number: 243
u could see if a local audio shop will build it for u
Username: Anthony1
Post Number: 60
i was hoping i could just buy it online but i'll call tomorrow n see if they will
Username: Sw9152
Michigan
Post Number: 469
thecaraudiobox.com
to save some time you could get plans from accelerator-pedal.com because they give you measurements for every piece of wood you will need. then go to Lowes and buy some mdf and have them cut all the pieces for you. then all you have to do is screw and liquid nails the box together. you cant tell me you cant spare an extra 30min to put the pieces together.
Username: Goatin
U.S.A
Post Number: 877
check Ebay it has boxs of all different sizes usually tuned ~35Hz. But expect to literaly pay 5 or 10 times what it would cost to build it yourself.
