Need help on a good amp
Username: Steve_collins
Post Number: 32
ok well i just baught 2 alpine type r and i need a good amp for around 250 dollars to power these. thanks a lot
Username: Goatin
U.S.A
Post Number: 859
are they 2 or 4 ohm?
Post Number: 33
they are the 1242d Dual 4 Ohm
Username: Redliner
Wilmington, Ma
Post Number: 1621
u should get the mb quart one that rovin had i forget wat it was called though something 1000 i believe based on if they are 2 ohm or 4 ohm
Username: Goatin
U.S.A
Post Number: 861
That is what I have I want to get a orion 1200.1 but that will most likely cost you about 300-350 shipped I have not priced one lately but in car audio you get what you pay for.
mb quart does make a good amp but I have never priced one I think the one rovin has is a bit more expensive. or if you can save up a bit more a Kicker KX1200.1 would be my first pick they are about 400 or more shipped.
Username: Redliner
Wilmington, Ma
Post Number: 1628
the one rovin had is only 260 i believe on wooferetc.com or close tot hat but under 300not sure on what ohms it runs at
Post Number: 34
how about the mtx thunder 942 amp is that anygood?
Username: Redliner
Wilmington, Ma
Post Number: 1630
ya its good i own it works perfectly fine puts out what its suppose to and then if u get a good one maybe more but i think the rms is only 700 at 4 homs bridged but if ur car is 14 volts it should run around 900
Post Number: 35
ok well is there a better amp for the r's around the smae price.
Username: Redliner
Wilmington, Ma
Post Number: 1634
umm that amp wul dbe fine but i would go witht he m quart over that i think its like the ra1000 or somehting close to that
Post Number: 37
do you know a sight that sells the mb quart like rovin has. thanks a lot
Username: Zepcoe
TN Us
Post Number: 202
i just bought that 2500d orion for 450 free ship
Username: Goatin
U.S.A
Post Number: 864
just had to rub it in hu Zep?Upload
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 112
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2424
doesnt put out quite what is says but it will work good with those subs
Username: Goatin
U.S.A
Post Number: 866
That amp may do 800 on a good day R's can take slightly more than their RMS and run fine.
I would get something with a bit more power than they need.
IMO a bit more than you need is always better than less because you can always turn down the gain.
