New member Username: Bholu_drpPost Number: 1 Registered: Apr-06 | i have DirecTV dish with single LNB facing east hooked up allready in my appartment. last tenant left this dish here . i just baught a Pansat 3500 SD . what satellte should i get with this dish right now ? what if i want 119 or 110 ? i put one BIN file in the reciever which shows all the channels and Lists and My fav. lists etc which was copied from another working Pansat reciever but there is no Picture. In menu-installation - antennae setup i can not get any signal quality. in this Menu i have echo 6&8 , Echo 7 , Echo3 allready . can someone help ?? |
Gold Member Username: LklivesPost Number: 2191 Registered: Jan-06 | U need to aim dish towards Mexico...this is NOT PLug N Play! |
New member Username: Bholu_drpPost Number: 2 Registered: Apr-06 | Thanks for the reply . My dish is facing south my LNB is (Cal Amp DirectTV Dual Output DBS LNBF 150517) What satellite should i select while scanning the satellites ? before i load any BIN files is there any way to check my signal strenth ? Thank you very much |
Gold Member Username: LklivesPost Number: 2257 Registered: Jan-06 | Why did U start a new thread when we have a very good thread FULL of info about the Pansat 3500..don't U look and read before U post?...thats why we hacve these forums and have SUBJECTS of topics/threads... https://www.ecoustics.com/electronics/forum/home-video/195282.html BTW...none of your multiple questions are about the pansat 3500...they are all about satellites and Dish pointing! If U have NO signal quality and level, then U don't have dish and LNB's aimed correctly and scans will not work...U can't scan a satellite that u do NOT receive good signals from! |
