Processors? which one to choose
Username: Hamjones2
Post Number: 10
O.K still not 100% sure on whether to choose a laptop with Centrino, Celeron, or AMD thingy in it. I'm not sure if I would need that wireless thing, and I have always been told to go with Centrino, but I keep seeing AMD's that look good. whats the difference between a 1.7GHz Centrino, and a 1.7GHz AMD processor. And why do I see 3.06Ghz AMD's for the same price as 1.8Ghz AMD's. Would this laptop be good enough to play the hightech games and all that, would it be as good as say... the Asus A3 with 1.73Ghz Centrino.
Processor & Cache Memory Mobile AMD Sempron Processor 128/256KB L2 cache, 25W 3100+, 1.8GHz
Operation System Microsoft Windows XP Home
Chipset SIS790 GX
Main Memory 1Gb DDR333 SDRAM, 2x SO-DIMM socket expandable to 2GB
Display 15.4" WXGA
Video Graphics & Memory EMBEDDED SIS790 GX
Video Camera
0.35 Mega Pixels web camera
Hard Drive 80GB
Optical Drive DVD-Dual
DVD-R/RW: 4X/2X or 8X/4X DVD+R/RW: 4X/2.4X or 8X/4X, CD-R/RW: 16X/10X or 24X/10X, DVD-ROM:8X, CD-ROM: 24X
Card Reader SD/MMC/MS/MS PRO
Fax/Modem/LAN/WLAN Integrated V.92 MDC Fax/Modem, with AC-Link Version. 2.1 Compliant.
AC 97 s/w MODEM and 10/100 Base T
PCI LAN on board
Pass and support worldwide regulation
IEEE 802.11b/g
LED Status Indicator Power-on/Suspend
Battery Charging/full/low
Storage device access
Capital / Scroll / Number Lock
E-mail in box
Wireless indicator
Interface 1 x Card-Reader
1 x TV-Out
1 Type II PCMCIA 2.1 compliant
1 x SIR-115.2Kbps supported
1 x IEEE 1394 port
1 x SPDIF Out jack
1 x Headphone-out jack
1 x Microphone-in jack
1 x Audio-in jack
1 x RJ11 Modem jack for phone line
1 x RJ45 LAN Jack for LAN insert
4 x USB 2.0 ports
1x EPP/ECP Parallel port/D-sub 25-pin
Hot Keys Instant launch Keys
4 buttons: Power4 Gear +, Email, Internet, Touchpad Lock
Function Keys
Fn+F1 Suspend switch
Fn+F2 Wireless switch
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Audio AC 97 S/W audio
SoundBlaster Pro Compatible
Built-in stereo speakers
Audio DJ Audio-DJ for play/pause, stop, forward, rewind
KeyBoard 19 mm full size 88key with MS-Windows function keys
Battery Pack & Life 8 cells, 4400mAh, 65Whrs
charging time: 4hrs/2.5hrs (System On/ Off) to 95%.
AC Adapter Output: 19 V DC, 3.42 A, 65W
Input: 100-- 240V AC, 50/60Hz universal
Dimension & Weight 354 x 284 x 35.2 mm (W x D x H)
2.65Kg --2.85 Kg (15"-15.4")
