Treo vs rockford fosgate
Username: Zepcoe
TN Us
Post Number: 141
2 Treo SSI 12" powered by a t10001bd vs 2 15 rockford fosgate t215d4 and i dont know what he is powered by. what would win?
Username: B101
Queen City, NC USA
Post Number: 2636
lol, the Treos are underpowred... and the 2 15s have more surface area than 2 12s...
Username: Sploosh56
Ohio
Post Number: 1258
the treo's will stomp all over those rf subs.
Username: Zepcoe
TN Us
Post Number: 146
so with 2 12 ssi they would win against what he had?
Username: B101
Queen City, NC USA
Post Number: 2644
depending on the install; anything is possible
Username: Zepcoe
TN Us
Post Number: 148
so what do you mean by install? the making of the box the placing of the amp and shi*t or just everything?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 979
the T2s are pretty powerful subs. if he has a decient amp with around 2000rms going to them then he will most likely take you in SPL. however they T2s do not sound god at all.
the SSi will win in SQ hands down. they are much better all around subs.
St. Louis, MO
Post Number: 980
ah when i read that i thought you had 2 T10001bds. YOU NEED MORE POWER MAN!
Username: Zepcoe
TN Us
Post Number: 152
o yea i meant to say a 5000d orion amp.. jake
Username: B101
Queen City, NC USA
Post Number: 2664
2 12 SSIs, on 2500d will be alot better match... if not get some 15s...
2 12s are in the same class as 1 15 bro!
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2677
yeah. in almost all cases the RFs will be louder. i mean just think about it, 2 15s agains 2 12s and its 2 SPL orientated 15s. however, id MUCH rather have the SSis . but if you get 2 ssi 15s you will have a match there :-)
