10w6 vs 12w6
Username: Whatisaboofy
im only lookin ta get 1 sub...would i be good with a 10w6...or you think i should go with the 12w6..n whats the diff?
Username: Young_james
Post Number: 1340
12w6 for one sub imo.....bigger surface area, and I would pick one 12 over 1 10.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2074
you'll find out here that there are subs cheaper than the w6 that will outperform it , but if you have to get it def. get the 12
Username: James1115
Ct
Post Number: 5720
"you'll find out here that there are subs cheaper than the w6 that will outperform it , but if you have to get it def. get the 12"
in SPL not in SQ! I have heard 1 12w6v2 do 146.3 db's so don't doubt the output of thhe w6 even though everyone seems to think they are a strict SQ sub. They have the ability to get pretty darn loud.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6749
thats not a daily setup though..for a daily setup i see where Casey is coming from...and from a spl setup i see where James is coming from, both make good points
Username: James1115
Ct
Post Number: 5727
I am running 1 12w6v2 in a ported enclosure and am ectremely happy with it's ability all around, but yes Chauncey i see your point.
