Pulling full power
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 326
i have 2 15's (300 watt pyramid and 500 watt clarion) pyramid is single voice coil, clarion is dvc. i have a (150x4) 4 channel 600 watt amp bridged to my clarion, i heard that if i some hoe wire from the clarion to the pyramid i can put 600 watts to both subs. instead of bridging each sub on its own and putting 300 watts to each sub a guy said i can get all 600 to both subs. is this true? if it is how can i do it?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 2640
you cant bridge 4 channels together... least not that i knwo of lol.
Post Number: 328
what do u mean?
Username: Sweatyogre
Erie, PA USA
Post Number: 81
If you could somehow bridge the 4 channels and wired the subs in parallel, I think you could do that. Like Trevor said though, I don't think you can bridge 4 channels.
Post Number: 331
k can i get a diagram or sumthin? right now im using 1 sub on a 4 chan 600 watt amp. its 150x4, but its a cheap no name amp so im probly only pushin about 400 watts. but when i hook up both so im using 2 of the 4 channels, its not so loud. less bass. and if that was 600 watts pushing then i would have messed sumthin up on my pyramid, it cant handle that much power...
Username: Van_man
Boston, MA
Post Number: 95
What like this...
Post Number: 333
nope...
Post Number: 335
http://i45.photobucket.com/albums/f89/Astrosafari/bridgin.jpg
like that, ther 2 ways i bridge there
Post Number: 336
[IMG]http://i45.photobucket.com/albums/f89/Astrosafari/bridgin.jpg[/IMG]
Post Number: 342
bump
Post Number: 2647
if your going to bridge it so its 2 x 300 at 4 ohms and one sub is dual 2 omhs and the other is SVc 4 ohms and your going to put a sub on each channel then yes, you can utilize all 600w.
Post Number: 343
but i want both pushin 600, if each only has 300 its not as loud as a single sub with 600
Post Number: 344
http://i45.photobucket.com/albums/f89/Astrosafari/untitled22.jpg what will this do? i think thats what the guy was trying to explain to me
Post Number: 345
-bump-
Post Number: 348
BUMP
Username: Lexuscoop
Phx, Arizona
Post Number: 1430
if you are giving both of them 600 RMS couldn't you blow the 300 watt sub?
Post Number: 350
im not worried about it
Post Number: 351
im not worried about it. i have tried to blow it, and it wont quit... so no worries
Post Number: 353
so if a 4 chan. cant be bridged, then im only putting 150 watts to my 15"?
Post Number: 354
heres my amp...
http://memimage.cardomain.net/member_images/7/web/2119000-2119999/2119735_147_fu ll.jpg
http://memimage.cardomain.net/member_images/7/web/2119000-2119999/2119735_152_fu ll.jpg
Username: Belike23
I need a schematic diagram for a Toshiba D-VKR3SU. Mainly the VCR door. I would greatly appreciate it!!!
Post Number: 355
!!is ac60 my amp brand? did a search and a bunch of roland guitar amps came up.
Post Number: 356
nope roland has nuthin to do with car audio.
says my amp was made in korea.
why cant i find my amp any where on the net??
Username: Lexuscoop
Phx, Arizona
Post Number: 1439
what would happen if your did bridge a 4 channel? would the amp fri?
Username: Langless28
Boston, MA
Post Number: 538
both subs cant possibly get 600 each, then the amp would have to be rated at 1200watts bridged
