Check out this amp!
Username: Stnorris
Post Number: 20
Kenwood amp
1,700 watts max output Mono amplifier
850 watts RMS @ 2 ohms
2 Ohm stable
500 watts RMS @ 4 ohms
Efficient Class D Circuitry
MOSFET Power Supply
Noise Suppression Filter
Copper Power Transformer
Dual Secondary Caps
Detachable Top Panel for Controls
Die-Cast Alluminum Heat Sink
Advanced Low Pass Crossover
18 dB / Octave Subsonic Filter
0-18 dB Bass Boost @ 90 Hz
Single-Side Terminal Placement for a more efficient install
Frequency Response: 5-200 Hz
Signal to Noise Ratio: 100 dB
what do you guys think?!?!?
i dont want to buy another piece of sh*t amp.
Username: Swisher
Marianna, FL
Post Number: 83
then dont get that :-) na i duno how much you spending then we can tell you what to get
Username: Shman
Grandville, Michigan United States
Post Number: 121
dont buy it!!
Username: Shman
Post Number: 122
find the post called like "1800rms @ 1 ohm" and contact sw9152, thats a lot better amp
