Need advice on speakers
Username: Theceo
Post Number: 83
im looking to upgrade my car door speakers seeing as how theyre stock right now, but im only going to replace the ones on the front and rear doors because i dont see a point in replacing the ones on the rear deck since i have subs. can you guys suggest some good ones? i was thinking of maybe going with kicker, and my price range is maybe 80-100 per pair. thanks guys
Username: Theceo
Post Number: 84
and i drive a 99 mazda protege, i think 6x9s are what fit, but im not sure.
Username: Adddisorder
West palm, Florida
Post Number: 179
because you ahve subs you should just cover up the front speaker hole with wood cut out a 6.5 hole and get some components and run them off an amp.
you can get a cheap pair of comps. online for around 100 then get the audiobahn a4002t like 100 online to run them and dont bother with rear speakers at all right now because they wont make much of a difference to you being in the front anyway
